    • Search
    • Wiki
    COOLPI CM5 AD7606 8-channel synchronous sampling
    Hardware
    1
    1
    776
      george last edited by george
      • Using SPI serial communication interface, the circuit is as follows
      • Standard IIO driver configuration
      diff --git a/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts b/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts
      index 5b04c9d3f354..550b320403d7 100755
      --- a/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts
      +++ b/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts
      @@ -486,6 +486,34 @@ &sdmmc {
      +&spi0 {
      +	status = "okay";
      +	assigned-clocks = <&cru CLK_SPI0>;
      +	pinctrl-names = "default";
      +	pinctrl-0 = <&spi0m2_cs0 &spi0m2_pins>;
      +	ad7606@0 {
      +            compatible = "adi,ad7606-8";
      +            reg = <0>;
      +            spi-max-frequency = <20000000>;
      +            spi-cpol;
      +            spi-cpha;
      +            avcc-supply = <&vcc5v0_sys>;
      +            interrupts = <8 IRQ_TYPE_EDGE_FALLING>;
      +            interrupt-parent = <&gpio1>;
      +            adi,conversion-start-gpios = <&gpio1 RK_PD2 GPIO_ACTIVE_HIGH>;
      +			adi,range-gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>;
      +            reset-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>;
      +            adi,oversampling-ratio-gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_HIGH>,
      +                                           <&gpio3 RK_PB6 GPIO_ACTIVE_HIGH>,
      +                                           <&gpio1 RK_PD6 GPIO_ACTIVE_HIGH>;
      +			pinctrl-0 = <&ad7606_busy &ad7606_conver &ad7606_range &ad7606_reset &ad7606_os0 &ad7606_os1 &ad7606_os2>;
      +            //adi,sw-mode;
      +			status = "okay";
       &dsi0 {
       	status = "disabled";
       	//rockchip,lane-rate = <1000>;
      @@ -1330,6 +1358,30 @@ &rng {
       &pinctrl {
      +	ad7606 {
      +		ad7606_busy: ad7606-busy {
      +			rockchip,pins = <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
      +		ad7606_conver: ad7606-conver {
      +			rockchip,pins = <1 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>;
      +		ad7606_range: ad7606-range {
      +			rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>;
      +		ad7606_reset: ad7606-reset {
      +			rockchip,pins = <1 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>;
      +		ad7606_os0: ad7606-os0 {
      +			rockchip,pins = <3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>;
      +		ad7606_os1: ad7606-os1 {
      +			rockchip,pins = <3 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up>;
      +		ad7606_os2: ad7606-os2 {
      +			rockchip,pins = <1 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>;
       	hym8563 {
       		hym8563_int: hym8563-int {
       			rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>;
      diff --git a/arch/arm64/configs/rk3588_cpcm5_evb_defconfig b/arch/arm64/configs/rk3588_cpcm5_evb_defconfig
      index 92e6983d3a40..9365319f866d 100644
      --- a/arch/arm64/configs/rk3588_cpcm5_evb_defconfig
      +++ b/arch/arm64/configs/rk3588_cpcm5_evb_defconfig
      @@ -891,6 +891,8 @@ CONFIG_ARM_ROCKCHIP_BUS_DEVFREQ=y
       CONFIG_ARM_ROCKCHIP_DMC_DEVFREQ=y
       CONFIG_DEVFREQ_EVENT_ROCKCHIP_NOCP=y
       CONFIG_IIO=y
      +CONFIG_AD7606_IFACE_PARALLEL=y
      +CONFIG_AD7606_IFACE_SPI=y
       CONFIG_ROCKCHIP_SARADC=y
       CONFIG_SENSORS_ISL29018=y
       CONFIG_SENSORS_TSL2563=y
      • test method
      Single sampling
      cat /sys/bus/iio/devices/iio:device0/in_voltage0_raw
      Continuous Samples
       /*Modify node permissions*/
      sudo chmod 777 /sys/bus/iio/devices/iio:device0/ -R
       /*Enable sampling channel*/
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage0_en  //
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage1_en
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage2_en
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage3_en
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage4_en
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage5_en
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage6_en
      echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage7_en
      /*Configure buffer size*/
      echo 128 > /sys/bus/iio/devices/iio:device0/buffer/length
      /*Start sampling*/
      echo 1 > /sys/bus/iio/devices/iio:device0/buffer/enable
      /*View Results*/
      cat /dev/iio\:device0 |xxd -
      • The schematic and PCB files can be downloaded from the wiki,Some empty PCBs can also be given away for free.
