我的几块板都是只能接U3上才能备份
接U3下 直接进系统
好像也不是不能还原 只是还原出来的系统好像只还原了一半
系统能进去 但是有些能操作 有些不能操作COOLPI LOADER BY YANYI(Apr 11 2023) DRAM: 8 GiB Using default environment 0 2 1 3 6 8 7 9 Monitor has basic audio support hdmi info isn't saved in main block mode:1920x1080 bus_format:0x100a hdmi@fde80000: detailed mode clock 148500 kHz, flags[5] H: 1920 2008 2052 2200 V: 1080 1084 1089 1125 bus_format: 100a VOP update mode to: 1920x1080p0, type: HDMI0 for VP0 dclk:148500,if_pixclk_div;2,if_dclk_div:4 rockchip_vop2_init: hdmi1_phy_pll may not define hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000 hdptx phy pll locked! VP0 set crtc_clock to 1485KHz VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000] CEA mode used vic=16 mtmdsclock:148500000 bus_width:0x16a8c8,bit_rate:1485000 hdptx phy lane locked! dw_hdmi_setup HDMI mode don't use dsc mode dw hdmi qp use tmds mode Autoboot in 1 seconds VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000] starting USB... Bus usb@fc000000: usb maximum-speed not found trsv ln0 mon rx cdr lock timeout Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fcd00000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fcd00000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device MMC: no card present mmc_init: -123, time 2 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 289 bytes read in 4 ms (70.3 KiB/s) 1: Linux coolpi Retrieving file: /initrd.img reading /initrd.img 8775086 bytes read in 51 ms (164.1 MiB/s) Retrieving file: /Image reading /Image 38031872 bytes read in 212 ms (171.1 MiB/s) append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:7a:46:da:5f:3e:bd Retrieving file: /rk3588s-cp4-dsi.dtb reading /rk3588s-cp4-dsi.dtb 142879 bytes read in 5 ms (27.3 MiB/s) ## Flattened Device Tree blob at 0x0a100000 Booting using the fdt blob at 0x0a100000 Loading Ramdisk to eb176000, end eb9d45ae ... OK Loading Device Tree to 00000000eb150000, end 00000000eb175e1e ... OK Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000) Starting kernel ... I/TC: Secondary CPU 4 initializing I/TC: Secondary CPU 4 switching to normal world boot I/TC: Secondary CPU 5 initializing I/TC: Secondary CPU 5 switching to normal world boot I/TC: Secondary CPU 6 initializing I/TC: Secondary CPU 6 switching to normal world boot I/TC: Secondary CPU 7 initializing I/TC: Secondary CPU 7 switching to normal world boot I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot [ 8.618626] rk-pcie fe190000.pcie: IRQ msi not found [ 8.618633] rk-pcie fe190000.pcie: Missing *config* reg space [ 8.618706] rk-pcie fe190000.pcie: Missing *config* reg space [ 8.618727] rk-pcie fe190000.pcie: invalid resource [ 8.621817] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 8.622959] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 8.622964] rkvdec2_init:1010: No niu aclk reset resource define [ 8.622968] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 8.622971] rkvdec2_init:1013: No niu hclk reset resource define [ 8.623491] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 8.623495] rkvdec2_init:1010: No niu aclk reset resource define [ 8.623499] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 8.623501] rkvdec2_init:1013: No niu hclk reset resource define [ 8.625244] mpp_iommu_probe:434: failed to get device node [ 8.625248] mpp_av1dec av1d-master: failed to attach iommu [ 8.751154] dw-mipi-dsi2 fde20000.dsi: [drm:dw_mipi_dsi2_bind] *ERROR* Failed to find panel or bridge: -517 [ 8.976170] rk806 spi2.0: no sleep-setting state [ 8.980788] rk806 spi2.0: no reset-setting pinctrl state [ 8.986092] rk806 spi2.0: no dvs-setting pinctrl state [ 9.199359] tinker-mcu: send_cmds: send command failed, ret = -6, retry again! [ 9.206715] tinker-mcu: send_cmds: send command failed, ret = -6, retry again! [ 9.214065] tinker-mcu: send_cmds: send command failed, ret = -6, retry again! [ 9.221414] tinker-mcu: send_cmds: send command failed, ret = -6, retry again! [ 9.228762] tinker-mcu: send_cmds: send command failed, ret = -6, retry again! [ 9.235972] tinker-mcu: send_cmds: send command failed [ 9.241104] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6 [ 9.810964] tinker-ft5406: tinker_ft5406_probe: wait connected timeout [ 9.829919] : terminal subdev does not exist [ 9.834192] : terminal subdev does not exist [ 9.838455] : terminal subdev does not exist [ 9.842718] : terminal subdev does not exist [ 9.846981] : get_remote_sensor: video pad[0] is null [ 9.852024] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed! [ 9.859239] : get_remote_sensor: video pad[0] is null [ 9.864283] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed! [ 9.871493] : get_remote_sensor: video pad[0] is null [ 9.876539] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed! [ 9.883749] : get_remote_sensor: video pad[0] is null [ 9.888795] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed! [ 9.897248] rockchip-mipi-csi2: Async registered subdev [ 9.966480] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 9.977668] debugfs: File 'Capture' in directory 'dapm' already present! [ 10.011151] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 10.207221] rockchip-drm display-subsystem: route-dsi0: failed to get logo,offset [ 10.581013] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready [ 10.944354] rockchip-pinctrl pinctrl: pin gpio1-15 already requested by fe4f0000.spdif-tx; cannot claim for febf0010.pwm [ 10.944355] rockchip-pinctrl pinctrl: pin-47 (febf0010.pwm) status -22 [ 10.944357] rockchip-pinctrl pinctrl: could not request pin 47 (gpio1-15) from group pwm13m2-pins on device rockchip-pinctrl [ 10.944359] rockchip-pwm febf0010.pwm: Error applying setting, reverse things back [ 11.166369] rockchip-pinctrl pinctrl: pin gpio1-14 already requested by 8-0010; cannot claim for 8-001a [ 11.175747] rockchip-pinctrl pinctrl: pin-46 (8-001a) status -22 [ 11.181741] rockchip-pinctrl pinctrl: could not request pin 46 (gpio1-14) from group cam-clkout0 on device rockchip-pinctrl [ 11.192934] imx477 8-001a: Error applying setting, reverse things back [ 11.332408] debugfs: File 'Left Hp mixer' in directory 'dapm' already present! [ 11.339621] debugfs: File 'Right Hp mixer' in directory 'dapm' already present! [ 11.346917] debugfs: File 'HPCP L' in directory 'dapm' already present! [ 11.353518] debugfs: File 'HPCP R' in directory 'dapm' already present! [ 11.360118] debugfs: File 'HPVOL L' in directory 'dapm' already present! [ 11.366804] debugfs: File 'HPVOL R' in directory 'dapm' already present! [ 11.375602] rockchip-pinctrl pinctrl: pin gpio1-14 already requested by 8-0010; cannot claim for 8-0036 [ 11.384982] rockchip-pinctrl pinctrl: pin-46 (8-0036) status -22 [ 11.390977] rockchip-pinctrl pinctrl: could not request pin 46 (gpio1-14) from group cam-clkout0 on device rockchip-pinctrl [ 11.402171] ov5648 8-0036: Error applying setting, reverse things back [ 11.410124] rockchip_headset rk-headset: Can not read property headset_gpio [ 11.418287] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 11.426801] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 11.435311] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 11.447019] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 11.476160] RKNPU fdab0000.npu: failed to find power_model node [ 11.482071] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 11.488671] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient writable: clean, 139176/1864128 files, 1593574/7444478 blocks [ 14.844411] cmd timed-out [ 14.847028] tkn[19] flags:0012 result: -4 cmd:1037 - reqcfm(1038) [ 14.853705] aicbsp: sdio_err:<aicwf_sdio_bustx_thread,1119>: sdio bustx thread stop [ 14.861469] aicbsp: sdio_err:<aicwf_sdio_busrx_thread,1138>: sdio busrx thread stop [ 16.977725] cmd timed-out [ 16.980413] tkn[0] flags:0012 result: -4 cmd: 123-MM_SET_STACK_START_REQ - reqcfm( 124-MM_SET_STACK_START_CFM) [ 16.990879] cmd queue crashed [ 16.993869] cmd queue crashed [ 16.996834] cmd queue crashed [ 16.999796] cmd queue crashed [ 17.002760] cmd queue crashed [ 17.005725] cmd queue crashed [ 17.008690] cmd queue crashed [ 17.011661] cmd queue crashed [ 17.014670] cmd queue crashed [ 17.018051] ieee80211 phy0: [ 17.018051] ******************************************************* [ 17.018051] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES ** [ 17.018051] ******************************************************* [ 17.039662] cmd queue crashed [ 17.042671] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000 [ 17.042672] Mem abort info: [ 17.042673] ESR = 0x96000045 [ 17.042675] EC = 0x25: DABT (current EL), IL = 32 bits [ 17.042675] SET = 0, FnV = 0 [ 17.042676] EA = 0, S1PTW = 0 [ 17.042677] Data abort info: [ 17.042677] ISV = 0, ISS = 0x00000045 [ 17.042678] CM = 0, WnR = 1 [ 17.042679] user pgtable: 4k pages, 39-bit VAs, pgdp=00000001010b7000 [ 17.042681] [0000000000000000] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000 [ 17.042685] Internal error: Oops: 96000045 [#1] SMP [ 17.042686] Modules linked in: aic8800_fdrv(+) aic8800_bsp [ 17.042691] CPU: 1 PID: 565 Comm: systemd-udevd Not tainted 5.10.110 #1 [ 17.042695] Hardware name: RK3588S CoolPi 4B Board DSI ENABLE (DT) [ 17.042700] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--) [ 17.122628] pc : rwnx_interface_add+0x300/0x490 [aic8800_fdrv] [ 17.122645] lr : rwnx_interface_add+0xd0/0x490 [aic8800_fdrv] [ 17.122646] sp : ffffffc012f63640 [ 17.122646] x29: ffffffc012f63640 x28: 0000000000000001 [ 17.122648] x27: ffffffc0094a8000 x26: 0000000000000000 [ 17.122649] x25: 0000000000000002 x24: ffffffc00947415c [ 17.122650] x23: ffffff81010157e0 x22: ffffff81010107e0 [ 17.122652] x21: ffffff81029338c0 x20: ffffff8102933000 [ 17.122653] x19: 0000000000000000 x18: 0000000000000030 [ 17.122654] x17: 0000000000000000 x16: 0000000000000000 [ 17.122656] x15: ffffffffffffffff x14: ffffffc092f632d7 [ 17.122657] x13: 0000000000020020 x12: ffffffc0123ab2e8 [ 17.122658] x11: ffffffc0123ab2d8 x10: 0000000000000068 [ 17.122659] x9 : ffffffc01108e9fc x8 : ffffff811728db00 [ 17.122661] x7 : 0000000000000000 x6 : 000000000000003f [ 17.122665] x5 : ffffffc0124a2000 x4 : ffffffc012f635b0 [ 17.201087] x3 : 00000000ff81042b x2 : ffffff8101010300 [ 17.201088] x1 : ffffff8102933942 x0 : 0000000000000000 [ 17.201090] Call trace: [ 17.201106] rwnx_interface_add+0x300/0x490 [aic8800_fdrv] [ 17.201123] rwnx_cfg80211_init+0x66c/0x880 [aic8800_fdrv] [ 17.230397] rwnx_platform_init+0x48/0x74 [aic8800_fdrv] [ 17.230411] aicwf_rwnx_sdio_platform_init+0x54/0x90 [aic8800_fdrv] [ 17.230426] aicwf_sdio_probe+0x114/0x2a0 [aic8800_fdrv] [ 17.230430] sdio_bus_probe+0x140/0x1ac [ 17.230433] really_probe+0x110/0x514 [ 17.230434] driver_probe_device+0x7c/0x170 [ 17.230436] device_driver_attach+0xcc/0xd4 [ 17.230437] __driver_attach+0xd8/0x17c [ 17.230438] bus_for_each_dev+0x7c/0xe0 [ 17.230442] driver_attach+0x30/0x40 [ 17.274318] bus_add_driver+0x12c/0x23c [ 17.274320] driver_register+0x84/0x140 [ 17.274321] sdio_register_driver+0x34/0x40 [ 17.274335] aicwf_sdio_register+0x28/0x34 [aic8800_fdrv] [ 17.274350] rwnx_mod_init+0x9c/0x1000 [aic8800_fdrv] [ 17.274352] do_one_initcall+0x68/0x290 [ 17.274355] do_init_module+0x50/0x260 [ 17.274356] load_module+0x2334/0x2a54 [ 17.274357] __do_sys_finit_module+0xd0/0x130 [ 17.274359] __arm64_sys_finit_module+0x2c/0x3c [ 17.274361] el0_svc_common.constprop.0+0xa4/0x2a0 [ 17.274362] do_el0_svc+0x78/0xa0 [ 17.274365] el0_svc+0x20/0x30 [ 17.274366] el0_sync_handler+0xe8/0xf0 [ 17.274367] el0_sync+0x1a0/0x1c0 [ 17.274368] [ 17.274368] PC: 0xffffffc00946db40: [ 17.274369] d940 f940c821 f9026e81 b90022b9 f9001eb4 79169e82 a9007c1f a9017c1f a9027c1f [ 17.274373] d960 a9037c1f a9047c1f a9057c1f a9067c1f a9077c1f a9087c1f a9097c1f a90a7c1f [ 17.274377] d980 f9059e9f 390d06bf 71001b3f 54001820 54000b28 71000f3f 54001520 7100133f [ 17.274381] d9a0 540013c1 aa1603e3 f8420c60 eb00007f 54001000 91002342 14000004 f9400000 [ 17.364462] d9c0 eb03001f 54000f60 b9402001 71000c3f 54ffff61 f940e001 b9400044 f9418021 [ 17.364465] d9e0 b9400025 6b0400bf 540014a0 f90152a0 91250a80 f90156bf f9418281 b9400043 [ 17.364469] da00 b9000023 79400843 79000823 b9400041 b9000001 b945a360 79400841 79128e81 [ 17.364472] da20 37080ac0 b4000bfa b9400740 7100001f 1a9f07e0 390a42a0 b9400741 f9417a80 [ 17.364476] da40 7100003f 1a9f07e1 3901a001 aa1403e0 95f0b3f8 35000ae0 d5384101 b9401020 [ 17.364480] da60 11080000 b9001020 d2800002 913492c0 52800023 f9800011 885ffc01 4a020024 [ 17.364483] da80 35000064 88047c03 35ffff84 35001101 f94016c1 f90016d5 910082c0 f9046280 [ 17.364487] daa0 f9046681 52800000 f9000035 913492c1 089ffc20 f0047ea1 92800000 aa1803fe [ 17.364490] dac0 d50320ff f9440821 9ac12000 b6b80b3e aa0003c0 52804001 95b0cb87 397342e1 [ 17.364494] dae0 d2800020 9ad32013 0a330033 393342f3 17ffff77 7100233f 54000b60 7100273f [ 17.364497] db00 54000601 912de280 912da281 f905b681 52800022 f905ba81 a9007c1f a9017c1f [ 17.364501] db20 a9027c1f a9037c1f f905de9f 390d06a2 f9400ec2 91250a81 f9418280 b9400043 [ 17.364505] db40* b9000003 79400842 79000802 f9418282 39401440 4a000260 39001440 f9418280 [ 17.364509] db60 b9400002 b9000022 79400800 79128e80 b945a360 360ff580 39421ea6 f0000180 [ 17.364512] db80 39421aa5 912f2000 394216a4 394212a3 39420ea2 39420aa1 95fe305b b5fff47a [ 17.486880] dba0 390a42bf aa1403e0 95f0b3a2 34fff560 aa1403e0 d2800015 95f082b6 17ffff44 [ 17.486883] dbc0 71001f3f 54fffb61 912f4282 f905ea82 912de280 912f8283 f905ee82 b20003e4 [ 17.486887] dbe0 f905f283 912da282 f905f683 390cc2bf b90336bf f905b682 f905ba82 f905fe84 [ 17.486891] dc00 a9007c1f a9017c1f a9027c1f a9037c1f f905de9f 17ffffc7 71000b3f 54fff8a1 [ 17.486895] dc20 f90152bf f90156bf 390ac2bf 17ffffc1 9240d800 8a2003c0 17ffffa7 912de280 [ 17.486898] dc40 912da281 f905b681 f905ba81 a9007c1f a9017c1f a9027c1f a9037c1f f905de9f [ 17.486902] dc60 17ffffb4 52800020 f90152bf f90156bf 390ac2bf 390d06a0 17ffffae 79400824 [ 17.486906] dc80 79400841 6b01009f 54ffeb21 17ffff4c f00000c0 910b0000 910b0000 52806461 [ 17.486909] dca0 f900fa80 79047a81 17ffffa2 95b273c1 17ffff78 2a1903e2 f0000180 52800143 [ 17.486913] dcc0 912e4000 95fe3010 17fffef1 d503201f d503245f aa1e03e9 d503201f d503233f [ 17.486916] dce0 a9bc7bfd 910003fd a90153f3 aa0003f3 a9025bf5 b4000ec0 91138016 7100287f [ 17.486920] dd00 54000180 12001c42 aa1603e0 97fffecd 91006014 b4000ce0 aa1403e0 a94153f3 [ 17.486924] dd20 a9425bf5 a8c47bfd d50323bf d65f03c0 aa0103f5 f0000180 2a0303e1 aa1503e2 [ 17.486927] [ 17.486927] LR: 0xffffffc00946d910: [ 17.486928] d710 95feefdc d503245f aa1e03e9 d503201f b4000620 d503233f a9bb7bfd 910003fd [ 17.486931] d730 a90153f3 f00001d4 aa0103f3 a9025bf5 91138015 b945a280 a90363f7 12003c57 [ 17.614247] d750 91230038 371005c0 37080480 b94b4a60 f00001d4 91168294 7100081f 540001e1 [ 17.614251] d770 f00000c0 910b0000 9116c016 f0000180 f90023f9 912d4019 b9400280 37000500 [ 17.614254] d790 52800c80 95b373d3 b94b4a60 7100081f 54ffff40 f94023f9 b94b4a60 71000c1f [ 17.614258] d7b0 54000061 52800020 b90b4a60 2a1703e2 aa1803e1 aa1503e0 97ffc8f2 a94153f3 [ 17.614262] d7d0 a9425bf5 a94363f7 a8c57bfd d50323bf d65f03c0 d4210000 394a3302 f00000c1 [ 17.614265] d7f0 910b0021 2a1703e3 9116c021 f0000180 912c4000 95fe3140 17ffffd5 f00000c1 [ 17.614269] d810 910b0021 9116c021 f0000180 91268000 95fe3139 b945a280 17ffffcc aa1603e1 [ 17.614272] d830 aa1903e0 95fe3134 17ffffd6 d503201f aa1e03e9 d503201f d503233f a9ba7bfd [ 17.614276] d850 910003fd f9002bfb f00001db a90153f3 aa0103f4 b945a365 a9025bf5 aa0003f6 [ 17.614279] d870 12001c55 a90363f7 aa1e03f8 a9046bf9 2a0303f9 aa0403fa 37082165 914016d7 [ 17.614283] d890 7100133f 52800080 1a9f0013 528001c5 1a8000a5 397342e6 9ad324c0 36000080 [ 17.614287] d8b0 14000010 9ad324c2 370001c2 11000673 6b05027f 54ffff8b d2800015 aa1503e0 [ 17.614290] d8d0 a94153f3 a9425bf5 a94363f7 a9446bf9 f9402bfb a8c67bfd d50323bf d65f03c0 [ 17.614294] d8f0 aa1403e1 2a1503e2 f0ffffe3 52800025 912dd063 52800a24 52807000 95f083b5 [ 17.614297] d910* aa0003f4 b4fffda0 3930029f 91236281 f9017a81 91230295 912a2280 52801fe2 [ 17.614301] d930 f9400ec1 a90106b6 f900e2b4 390a32b3 f940c821 f9026e81 b90022b9 f9001eb4 [ 17.744824] d950 79169e82 a9007c1f a9017c1f a9027c1f a9037c1f a9047c1f a9057c1f a9067c1f [ 17.744828] d970 a9077c1f a9087c1f a9097c1f a90a7c1f f9059e9f 390d06bf 71001b3f 54001820 [ 17.744832] d990 54000b28 71000f3f 54001520 7100133f 540013c1 aa1603e3 f8420c60 eb00007f [ 17.744835] d9b0 54001000 91002342 14000004 f9400000 eb03001f 54000f60 b9402001 71000c3f [ 17.744839] d9d0 54ffff61 f940e001 b9400044 f9418021 b9400025 6b0400bf 540014a0 f90152a0 [ 17.744842] d9f0 91250a80 f90156bf f9418281 b9400043 b9000023 79400843 79000823 b9400041 [ 17.744846] da10 b9000001 b945a360 79400841 79128e81 37080ac0 b4000bfa b9400740 7100001f [ 17.744849] da30 1a9f07e0 390a42a0 b9400741 f9417a80 7100003f 1a9f07e1 3901a001 aa1403e0 [ 17.744853] da50 95f0b3f8 35000ae0 d5384101 b9401020 11080000 b9001020 d2800002 913492c0 [ 17.744856] da70 52800023 f9800011 885ffc01 4a020024 35000064 88047c03 35ffff84 35001101 [ 17.744860] da90 f94016c1 f90016d5 910082c0 f9046280 f9046681 52800000 f9000035 913492c1 [ 20.217063] b488 123ab488 ffffffc0 123ab488 ffffffc0 123ab498 ffffffc0 123ab498 ffffffc0 [ 20.217067] b4a8 123ab4a8 ffffffc0 123ab4a8 ffffffc0 00000002 00000000 123ab4c0 ffffffc0 [ 20.217070] b4c8 123ab4c0 ffffffc0 123ab4d0 ffffffc0 123ab4d0 ffffffc0 0443c008 ffffffff [ 20.217074] [ 20.217074] X14: 0xffffffc092f632d7: [ 20.217075] 30d4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.217081] 30f4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.217086] 3114 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.217090] 3134 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.217094] 3154 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.217099] 3174 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336344] 3194 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336349] 31b4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336353] 31d4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336357] 31f4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336362] 3214 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336366] 3234 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336371] 3254 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336375] 3274 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336380] 3294 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336384] 32b4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336388] 32d4* ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336393] 32f4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.336397] 3314 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442451] 3334 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442456] 3354 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442460] 3374 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442465] 3394 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442469] 33b4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442474] 33d4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442478] 33f4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442483] 3414 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442487] 3434 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442492] 3454 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442496] 3474 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.442500] 3494 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.540395] 34b4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.540399] 34d4 ******** ******** ******** ******** ******** ******** ******** ******** [ 20.540404] [ 20.540404] X20: 0xffffff8102933000: [000000 [ 22.387390] 37a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 22.395552] 37c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 22.403713] 37e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 22.411874] 3800 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 22.420036] 3820 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 22.428199] Code: f9400ec2 91250a81 f9418280 b9400043 (b9000003) [ 22.434279] ---[ end trace 0b1f44e8286bee41 ]--- [ 22.447752] Bluetooth: hci0: command 0x1003 tx timeout [ 22.881409] systemd-journald[517]: File /var/log/journal/9bae7872cb8c87ba609757ea648843cd/user-1001.journal corrupted or uncleanly shut down, renaming and replacing. [ 23.228220] mali fb000000.gpu: Loading Mali firmware 0x1010000 [ 23.235558] mali fb000000.gpu: Mali firmware git_sha: 9b8db9aa05a7b4f3066fd75dbdff695262f891fe [ 23.698696] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.709087] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.725752] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.742423] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.759088] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.775767] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.792436] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.809108] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.825748] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.842445] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.859098] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.875772] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.892435] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 23.909103] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 24.243479] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 24.292455] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 24.309062] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 24.657686] Bluetooth: hci0: command 0x1001 tx timeout [ 25.920017] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0 [ 25.925598] rockchip-vop2 fdd90000.vop: pd0 on [ 26.038286] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1 [ 26.043880] rockchip-vop2 fdd90000.vop: pd0 off [ 26.794314] Bluetooth: hci0: command 0x1009 tx timeout [ 27.404320] usb 1-1.4: new high-speed USB device number 3 using ehci-platform [ 27.511664] usb 1-1.4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 27.520053] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 27.527412] usb 1-1.4: Product: USB 2.0 Hub [ 27.532140] hub 1-1.4:1.0: USB hub found [ 27.536333] hub 1-1.4:1.0: 4 ports detected [ 27.937708] usb 1-1.4.2: new low-speed USB device number 4 using ehci-platform [ 28.162378] usb 1-1.4.2: New USB device found, idVendor=17ef, idProduct=600e, bcdDevice= 1.00 [ 28.170922] usb 1-1.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 28.178419] usb 1-1.4.2: Product: Lenovo USB Optical Mouse [ 28.183911] usb 1-1.4.2: Manufacturer: PixArt [ 28.191549] input: PixArt Lenovo USB Optical Mouse as /devices/platform/fc800000.usb/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.0/0003:17EF:600E.0001/input/input4 [ 28.205394] hid-generic 0003:17EF:600E.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-fc800000.usb-1.4.2/input0 [ 28.391029] usb 1-1.4.3: new high-speed USB device number 5 using ehci-platform [ 28.595633] usb 1-1.4.3: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 28.604150] usb 1-1.4.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 28.611651] usb 1-1.4.3: Product: USB 2.0 Hub [ 28.616550] hub 1-1.4.3:1.0: USB hub found [ 28.620825] hub 1-1.4.3:1.0: 4 ports detected [ 29.021010] usb 1-1.4.3.1: new low-speed USB device number 6 using ehci-platform [ 29.249119] usb 1-1.4.3.1: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.15 [ 29.257805] usb 1-1.4.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 29.265456] usb 1-1.4.3.1: Product: Lenovo Traditional USB Keyboard [ 29.271717] usb 1-1.4.3.1: Manufacturer: LiteOn [ 29.291141] input: LiteOn Lenovo Traditional USB Keyboard as /devices/platform/fc800000.usb/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3.1/1-1.4.3.1:1.0/0003:17EF:6099.0002/input/input5 [ 29.361329] hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [LiteOn Lenovo Traditional USB Keyboard] on usb-fc800000.usb-1.4.3.1/input0 [ 29.380032] input: LiteOn Lenovo Traditional USB Keyboard System Control as /devices/platform/fc800000.usb/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3.1/1-1.4.3.1:1.1/0003:17EF:6099.0003/input/input6 [ 29.451182] input: LiteOn Lenovo Traditional USB Keyboard Consumer Control as /devices/platform/fc800000.usb/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3.1/1-1.4.3.1:1.1/0003:17EF:6099.0003/input/input7 [ 29.468361] hid-generic 0003:17EF:6099.0003: input,hidraw2: USB HID v1.11 Device [LiteOn Lenovo Traditional USB Keyboard] on usb-fc800000.usb-1.4.3.1/input1 [ 42.151316] vcc_3v3_sd_s0: disabling
有没有其它方法备份、还原的 手动的也行
@jugg 所以确认你的rootfs包是不是ok的。备份与安装过程,U盘是比较重要的,质量尽量选择好的
我试过解压rootf 可以解压 -
而且我这里要接U3下面的口才能备份
接上面的直接进系统 -
@jugg 一个是接电脑刷loader,一个接U盘刷系统。
我的几块板都是只能接U3上才能备份
接U3下 直接进系统 -
我的几块板都是只能接U3上才能备份
接U3下 直接进系统 - topic:timeago_later,2 months
有没有其它方法备份、还原
这根本还原不了 还原出来的也是残缺的系统 -
手动的方法 有没有
这么多板 我不能一台一台的去设置吧
@jugg 几个板环境确认下。接串口查看下上电loader信息
这些在前面的回答中都有 -
@jugg 硬件没问题。或者用TF卡实现备份、还原安装。另一种方式,可以进入UMS模式,用USB线直接克隆还原
UMS进不去
卡在那个X那里 但是电脑上面识别不到
其它板是可以进入UMS的 -
@jugg 把loader擦除重新刷一次。
用这个刷过了 -
刷的这个
是不是有什么特别的地方
放两天板子的系统就进不去 又是怎么回事
串口有问题 又是怎么回事 -
@jugg 没有什么特殊的。
是不是有什么特别的地方
放两天板子的系统就进不去 又是怎么回事
串口有问题 又是怎么回事确认串口连接线是否松了或接对
- topic:timeago_later,10 months
没找到下载备份镜像的地址呢?可以发一下吗?
你是要用U盘刷机吗?最近的镜像是IMG文件,只能使用USB接口连接电脑,通过etcher刷机。
