Coolpi 4b Ubuntu20.04 原生系统
Ubuntu20 原生系统测试版
[离线刷机方式,兼容树莓派刷机操作模式]
[更新:自动根分区扩容,预装python3.9,预装docker,预装npu仓库,桌面默认自动登陆,预装中文输入法]
百度网盘
用户名 coolpi 密码 coolpi刷机操作请参考:
https://www.cool-pi.com/topic/126/coolpi-4b-镜像固件离线刷机方法 -
大法师 Dec 19, 2022, 1:38 AM
@大法师 你好,请教下这个unbut20.04版本好像没有适配npu的驱动,跑rknpu2仓库自带的sample一直报错:
E RKNN: [12:38:07.956] failed to open rknpu module, need to insmod rknpu dirver!
E RKNN: [12:38:07.958] failed to open rknn device!
不重刷其他版本系统,需要怎么处理呢?谢谢~ -
不行呢,尝试了一下,还是报 insmod rknpu driver的错误 -
@night 加sudo运行试下
coolpi@coolpi:~/rknpu2/examples/rknn_api_demo/install/rknn_api_demo_Linux$ export LD_LIBRARY_PATH=./lib coolpi@coolpi:~/rknpu2/examples/rknn_api_demo/install/rknn_api_demo_Linux$ sudo ./rknn_create_mem_with_rga_demo model/RK3588/mobilenet_v1.rknn model/dog_224x224.jpg rknn_api/rknnrt version: 1.4.0 (a10f100eb@2022-09-09T09:07:14), driver version: 0.8.2 model input num: 1, output num: 1 input tensors: index=0, name=input, n_dims=4, dims=[1, 224, 224, 3], n_elems=150528, size=150528, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=0, scale=0.007812 output tensors: index=0, name=MobilenetV1/Predictions/Reshape_1, n_dims=2, dims=[1, 1001, 0, 0], n_elems=1001, size=1001, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003906 custom string: rga_api version 1.8.0_[0] Begin perf ... 0: Elapse Time = 2.04ms, FPS = 489.72 ---- Top5 ---- 0.984375 - 156 0.007812 - 155 0.003906 - 205 0.000000 - 0 0.000000 - 1 coolpi@coolpi:~/rknpu2/examples/rknn_api_demo/install/rknn_api_demo_Linux$ sudo ./rknn_create_mem_demo model/RK3588/mobilenet_v1.rknn model/dog_224x224.jpg rknn_api/rknnrt version: 1.4.0 (a10f100eb@2022-09-09T09:07:14), driver version: 0.8.2 model input num: 1, output num: 1 input tensors: index=0, name=input, n_dims=4, dims=[1, 224, 224, 3], n_elems=150528, size=150528, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=0, scale=0.007812 output tensors: index=0, name=MobilenetV1/Predictions/Reshape_1, n_dims=2, dims=[1, 1001, 0, 0], n_elems=1001, size=1001, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003906 custom string: Begin perf ... 0: Elapse Time = 2.06ms, FPS = 484.50 ---- Top5 ---- 0.984375 - 156 0.007812 - 155 0.003906 - 205 0.000000 - 0 0.000000 - 1
@大法师 还真的是这个原因,sudo就可以,谢谢~
coolpi@coolpi:~/develop/rknpu2/examples/rknn_api_demo/install/rknn_api_demo_Linux$ export LD_LIBRARY_PATH=./lib coolpi@coolpi:~/develop/rknpu2/examples/rknn_api_demo/install/rknn_api_demo_Linux$ sudo ./rknn_create_mem_with_rga_demo model/RK3588/mobilenet_v1.rknn model/dog_224x224.jpg [sudo] password for coolpi: rknn_api/rknnrt version: 1.4.0 (a10f100eb@2022-09-09T09:07:14), driver version: 0.8.2 model input num: 1, output num: 1 input tensors: index=0, name=input, n_dims=4, dims=[1, 224, 224, 3], n_elems=150528, size=150528, fmt=NHWC, type=INT8, qnt_type=AFFINE, zp=0, scale=0.007812 output tensors: index=0, name=MobilenetV1/Predictions/Reshape_1, n_dims=2, dims=[1, 1001, 0, 0], n_elems=1001, size=1001, fmt=UNDEFINED, type=INT8, qnt_type=AFFINE, zp=-128, scale=0.003906 custom string: rga_api version 1.8.0_[0] Begin perf ... 0: Elapse Time = 1.97ms, FPS = 508.13 ---- Top5 ---- 0.984375 - 156 0.007812 - 155 0.003906 - 205 0.000000 - 0 0.000000 - 1 coolpi@coolpi:~/develop/rknpu2/examples/rknn_api_demo/install/rknn_api_demo_Linux$ ./rknn_create_mem_with_rga_demo model/RK3588/mobilenet_v1.rknn model/dog_224x224.jpg E RKNN: [21:30:43.503] failed to open rknpu module, need to insmod rknpu dirver! E RKNN: [21:30:43.503] failed to open rknn device! rknn_init fail! ret=-1
@大法师 22.04的镜像什么时候更新呢
@allen 22.04已有更新。
This post is deleted! -
这两个镜像,我试了下,Xbox手柄都不行,免驱的(我的是无线手柄)。
原生的Ubuntu20 可以的
找不到 /dev/input/js0 -
@ccjjww1222
默认内核驱动未选择CONFIG_INPUT_JOYDEV。后续默认选配再发布镜像,当然您也可以自行编译更新替换
@大法师 啥时候能发布? 我自己编译的话,系统挂了。重新安装还要重新编译,麻烦。等你们的镜像
请问一下,相同系统版本号,不同日期上传的特性哪里有介绍么?
为什么我 两张闪迪 一张京东卡 离线刷 只有京东卡可以用,闪迪的不能用,而树莓派三张卡全能用,而京东卡虽然读取速度也有100MB/s 但巨卡,20.04 鼠标都卡的动不了开机得10分钟是什么原因
@myhexb 串口打印一下启动的日志信息,发上来。
@myhexb 用哪个镜像文件测试?
@george 完全启动不起来 可以打印日志吗 该怎么打印 反复显示 cool pi
@大法师 用的官方文件百度网盘ubuntu文件夹里的 20.04桌面版 3.52g的那个
@大法师 闪迪的卡就像没插卡一样,反复显示 coolpi 京东卡可以进去 但特别卡,而且非正常关机后大概率也会进不去系统,不过一般会卡到 - 界面。需要重新刷机才行
@george 嫊-oZp@fde50000 disconnected
hdmi@fde80000 disconnected
scanning usb for storage devices... 0 Storage Device(s) foundDevice 0: unknown device
mmc1 is current device
Scanning mmc 1:1...
287 bytes read in 8 ms (34.2 KiB/s)
1: Ubuntu coolpi
8775086 bytes read in 709 ms (11.8 MiB/s)
37294592 bytes read in 2992 ms (11.9 MiB/s)
append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:52:84:fe:01:16:93
141784 bytes read in 18 ms (7.5 MiB/s)Flattened Device Tree blob at 0x0a100000
Loading Device Tree to 00000000eb150000, end 00000000eb1759d7 ... OK
Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000)Starting kernel ...
[ 8.386768] rk-pcie fe190000.pcie: IRQ msi not found
[ 8.386784] rk-pcie fe190000.pcie: Missing config reg space
[ 8.386875] rk-pcie fe190000.pcie: Missing config reg space
[ 8.386902] rk-pcie fe190000.pcie: invalid resource
[ 8.389687] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 8.390791] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 8.390796] rkvdec2_init:1010: No niu aclk reset resource define
[ 8.390799] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 8.390802] rkvdec2_init:1013: No niu hclk reset resource define
[ 8.391320] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 8.391324] rkvdec2_init:1010: No niu aclk reset resource define
[ 8.391327] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 8.391330] rkvdec2_init:1013: No niu hclk reset resource define
[ 8.393004] mpp_iommu_probe:434: failed to get device node
[ 8.393008] mpp_av1dec av1d-master: failed to attach iommu
[ 8.517456] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[ 8.525303] rockchip-drm display-subsystem: failed to show kernel logo
[ 8.704582] rk806 spi2.0: no sleep-setting state
[ 8.709201] rk806 spi2.0: no reset-setting pinctrl state
[ 8.714503] rk806 spi2.0: no dvs-setting pinctrl state
[ 8.926386] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[ 8.933738] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[ 8.941087] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[ 8.948434] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[ 8.955782] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[ 8.962994] tinker-mcu: send_cmds: send command failed
[ 8.968123] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
[ 9.539506] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
[ 9.620266] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 9.630200] debugfs: File 'Capture' in directory 'dapm' already present!
[ 9.652203] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
[ 9.851268] ov5647 8-0036: Unsupported clock frequency: 24000000
[ 9.991259] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
[ 9.998472] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
[ 10.005768] debugfs: File 'HPCP L' in directory 'dapm' already present!
[ 10.012367] debugfs: File 'HPCP R' in directory 'dapm' already present!
[ 10.018969] debugfs: File 'HPVOL L' in directory 'dapm' already present!
[ 10.025654] debugfs: File 'HPVOL R' in directory 'dapm' already present!
[ 10.034611] rockchip_headset rk-headset: Can not read property headset_gpio
[ 10.042867] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
[ 10.051384] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
[ 10.059894] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
[ 10.072022] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
[ 10.100903] RKNPU fdab0000.npu: failed to find power_model node
[ 10.106814] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 10.113414] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
Gave up waiting for root file system device. Common problems:- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! LABEL=writable does not exist. Dropping to a shell!
BusyBox v1.30.1 (Ubuntu 1:1.30.1-7ubuntu3) built-in shell (ash)
Enter 'help' for a list of built-in commands.(initramfs) [6n
@george DDR V1.09 a930779e06 typ 22/11/21-17:50:56
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 D镈DR V1.09 a930779e06 typ 22/11/21-17:50:56
CH0 RX Vref:29.7%, TX Vref:21.8%,21.8%
CH1 RX Vref:30.7%, TX Vref:21.8%,22.8%
CH2 RX Vref:30.7%, TX Vref:20.8%,20.8%
CH3 RX Vref:29.7%, TX Vref:22.8%,22.8%
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-481-g17b41886e:derrick.huang
NOTICE: BL31: Built : 16:20:07, Dec 7 2022
INFO: spec: 0x13
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022骞?09鏈?20鏃?鏄熸湡浜?09:41:09 CST aarch64
INFO: SPSR = 0x3c9COOLPI LOADER BY YANYI(Jan 04 2023)
DRAM: 8 GiB
Using default environment0 2 1 3 6 8 7 9 trsv ln0 mon rx cdr lock timeout
Card did not respond to voltage select!
mmc_init: -95, time 17
Loading order: usb - tf - emmc
bank id invalid
request for 141 failed:-22
bank id invalid
resetting USB...
** Bad device usb 0 **
mmc_init: -95, time 16
** Bad device mmc 0 **
CH3 RX Vref:30.7%, TX Vref:22.8%,22.8%
INFO: spec: 0x13
INFO: ext 32k is valid
DRAM: 8 GiB
bank id invalid
bank id invalid
resetting USB...
scanning bus usb@fc880000 for devices...这个是完全启动 不起来的日志
@myhexb 这个是镜像没有制作成功。如果有读卡器可以先格式化一次卡,然后再制作,闪迪的卡我一直在用,没有什么问题。
@george 第一张闪迪卡各种方式格式化 试了4 5次了 ,第二张也试了一次 还是不行
@myhexb 可以换个镜像再测试。从log看的情况就是卡没有识别到或者rootfs没有成功挂载。
@george 换22.04 也还是一样的情况
@myhexb 用读卡器连接,插在USB3下层端口,启动试试
@大法师 试了 usb插 硬盘盒子和 读卡器 还是只有京东卡可以启动,闪迪卡可以找到卡 但不能启动 ,重做和换镜像文件都没成功,0 2 1 3 6 8 7 9 trsv ln0 mon rx cdr lock timeout
scanning usb for storage devices... 1 Storage Device(s) foundDevice 0: Vendor: Generic Rev: 1532 Prod: STORAGE DEVICE
Capacity: 60906.0 MB = 59.4 GB (124735488 x 512)
** Unrecognized filesystem type ** -
@大法师 硬盘盒子干脆就找不到usb设备 ,
@myhexb said in Coolpi 4b Ubuntu20.04 原生系统:
硬盘盒需要更新loader,且需要注意适配器供电功率
https://www.cool-pi.com/topic/170/coolpi-4b-loading-from-usb-ssd
